Is ETM contactless mod kit still available?
goVolvo
- Year and Model: V70XC 2000, S70 1998
I replaced my ETM with a used XeMODex one. My old one still works well except for the ETS light for position sensor reading problem. If the contactless mod kit is still available somewhere I can mod the old one to make it reusable. Thanks a lot.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
The instructions that come from sacer are basic at best. You'll want to read up on the forum before doing it.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
precopster
- Year and Model: Lots
- Been thanked: 128 times
I haven't seen a faulty contactless sensor yet. It may pay to look up sensor 1 & 2 on Vida and compare the values or do a sweep test. They will likely be within spec.
I have an ETM that works perfectly with a contactless however just like yours calls up a sensor fault. The sensor fault comes up as a green status sensor 2 fault. This is as rare a fault as you can get. No limp home mode and perfect throttle response. Only problem is an ETS light. I've swapped out the contactless with another one only to get the same problem.
Is XeModex's warranty transferable? There will be a service sticker with some info on the ETM. A call to them may identify the unit.
goVolvo
In my case, the faulty ETM I took out is not contactless sensor and still works for driving. I swap in a XeMODex one, hopefully will not fail again. Now I am thinking to rebuild the faulty one with contactless sensor and it will be useful again for me or other people when need it, instead of junk it.precopster wrote:I haven't seen a faulty contactless sensor yet. It may pay to look up sensor 1 & 2 on Vida and compare the values or do a sweep test. They will likely be within spec.
- 2466 Views
Last post by 800artfreed
- 10439 Views
- 54 Replies
- 4016 Views
- 2630 Views
Last post by doublebug
- 3967 Views
Last post by Sigmarus
