Charging question
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
5ft24
Year and Model: 2005 XC90 V8 AWD
Has thanked: 20 times
Been thanked: 12 times
Charging question
Post by 5ft24 »
I have a 1990 740GL.
When I drive with the headlights on, the alternator charges less than adequately... at Idle, below 1000 RPM, the voltmeter will drop almost to the bottom... A volt meter on the battery shows 13.6 or so at idle with no accessories on. When I turn on the headlights, I have about 11.8-12.0 at the battery.
On the alternator, there is a piece of 12guage wire from a small stud on the rear to the Idle speed control bracket serving as a ground. It's hot as heck and shows a voltage drop of over 1 volt across it.
Is this the way the alternator is supposed to be grounded?
Thanks
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
That is how the alternator is earthed (grounded), although I can't recall the exact location, the idle speed bracket does not seem familiar. However, if the wire is getting hot it is either not strong enough or it is failing. I would replace it with something heavier and would be looking at a better earth point.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
5ft24
Post by 5ft24 »
Thanks, Bill
I'm going to see if I can make a shorter and heavier ground path for this guy...
Thanks
5ft24
Post by 5ft24 »
Used a length of #4 wire. No more voltage drop, but still weak charging. Pulled the regulator and there was nothing left of the brushes. (345K miles). New regulator and it's like new!
