Idle is Low, and lf need to adjust the idle
harleyvolvo
- Year and Model: 1998 S70 Volvo
I have a 1989 740....when my dad had it the idle seemed to high, but when I got it he turned the idle down...now the car is so low until it turns off.....so me being mr. Fix it I tried to increase the accelerator or increase the idle and I ended up messing up the connection to the gas pedal...it's too lose....how do I go about tightening it back up and increasing the idle so that the car doesn't turn off?????
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The idle on the 740 with the Jetronic LH 2.4 is not adjustable. It is computer controlled.
Low idle is usually caused by a dirty throttle body, a thing that is always overlooked until it causes a problem.
I am curious as to how your dad did reduce the idle speed. One possibility is that he adjusted the throttle position screw (TPS).
Next curiosity point - what did you loosen to mess things up? Throttle cable or throttle link rod?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 957 Views
Last post by psykojezus
- 44 Replies
- 8208 Views
Last post by Rattnalle
