I hooked my laptop up to the ODB-II port the other day in the hopes of accessing some data from my transmission and discovered a component failure as indicated below. Does anyone have any idea what this means, and what if anything, I can/should do about it?
Service $06 - On-Board Monitoring
Component Description Value Minimum Maximum Units Result
Component Id $00 TID $82 - Manufacturer Defined 34 N/A 128 Pass
Component Id $00 TID $83 - Manufacturer Defined 0 N/A 128 Pass
Component Id $00 TID $86 - Manufacturer Defined 16 N/A 128 Pass
Component Id $00 TID $87 - Manufacturer Defined 30 N/A 128 Pass
Component Id $00 TID $88 - Manufacturer Defined 15 N/A 128 Pass
Component Id $7F TID $C0 - Manufacturer Defined 0 1 N/A Fail
--Gregor
2000 V70 ODB-II "Component Failure"
- 18 Replies
- 8602 Views
Last post by rspi
- 1382 Views
Last post by esl_97_850_T5
- 1241 Views
- 279 Views
Last post by cmdz
- 918 Views
Last post by matthew1
