Cabin air filter housing fills with water...
jaces_dad
- Year and Model: 2001 V70 XC70
Im guessing my a/c condensation is filling my cabin air filter housing, anyone know where the drain is? the pools of water on my floors are getting old fast, thanks in advance
tailor
- Year and Model: 2004 XC90 2.5T AWD
- Been thanked: 2 times
You could have a blockage in the drain or pipe, this is found on the right side, assuming left hand drive,passenger side on the sidewall under the carpet.
You will have to remove the kick panel to gain access and pul back the carpet. Move the front seat as far back as it will go, it just makes the contorting easier.
The other possibility is the sunroof drains could be blocked. There are some posts here on how to unblock the drains and make suitable "repairs" to resolve the issue.
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
Abe Gottschalk
jimmy57
- Been thanked: 320 times
You likely have a lot of water under and in the foam blocks that raise the floor level on XC90 models. If you open doors, latch all door latches with screw driver, and then set fans (in sunlight) all day you should get it dried without too much work.
I agree with A/C drain being plugged.
