I was inspecting my serpentine belt and tensioner, and I noticed that I could wobble the tensioner pulley back and forth by hand with the belt still attached. Is this normal? Also, I've been having this problem with a odd squeaking noise on a cold start for the first few minutes. Could this be related?
Thanks
2000 V70 XC Serpentine Belt Tensioner
bags519
- Year and Model: 2000 V70 XC
Yep, replace the belt and the tensioner pulley.
Current Vehicles
2000 V70 XC (New Project)
2000 S70 SE 2.4 Manual (Daughter)
2004 VW Jetta GLS (Daughter #2)
1997 Chevy K1500 (Work)
2002 Chevy Silverado (Son)
2006 Audi A8
1985 Yamaha Venture Royale
2006 Audi A8
bags519
Current Vehicles
2006 Audi A8
2006 Audi A8
precopster
- Year and Model: Lots
- Been thanked: 128 times
'99s and 2000s have a different system with either a 14mm nut hiding under a removable plastic cap or a torx 60 hole on the tensioner. You need a torch to see it as it's quite a lot lower than the pre '99 setup.
- Been thanked: 472 times
If it is a Torx for later models, some people weld the Torx bit into an old lawn mower blade. Info here:
http://forums.swedespeed.com/showthread ... ioner-Tool
Cool, I checked; it's a 14mm on mine. I suppose a Snap On stubby torx would work if needed. A lot of the aftermarket tensioners use a T60. They have one with a 14mm hex for $50 at Advance Auto Parts with a lifetime warranty.
2000 V70XC 160,000mi.
quitequick
- Year and Model: V70 T5 2001
My heart sank when I saw that. My mechanic skills don't extend to welding. But you don't need anything like that. I replaced my serpentine belt and slackened the tensioner using a standard T60 torx bit on a half inch ratchet. It's a tight fit to get the bit in the hole, but its doable with some wiggling.cn90 wrote:If it is a Torx for later models, some people weld the Torx bit into an old lawn mower blade. Info here:
The hard part is threading the new belt around the pulleys and fighting the kinks in the belt from when it was in its packing. And you have to get the torx bit on the correct side of the belt so you can loosen the tensioner to get the new belt on - put the torx bit into its hole before you thread the belt.
Oh and absolutely do take a picture of the belt routing or make a sketch. I guarantee you will not be remember how it went if you don't!
- Has thanked: 1505 times
- Been thanked: 3818 times
PIcture of routing for reference
- Routing of V70 Drive Belt
- V70 Drive belt routing.png (242.82 KiB) Viewed 3250 times
