1998 V90 Keyless Entry Problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
mbsimmons
Year and Model: 02 V70, 98 V90
Post by mbsimmons »
Hello,
I have a 98 V90. Remote stopped working. Replaced batteries. Will not program. The remote makes it's quiet little chirp, but nothing happens inside the car. I think I remember that I used to hear a relay sound inside. But nothing happens. Central locking system works fine with key and inside. Alarm does set when locking the door with a key.
Looking for ideas of where to start. Is there a fuse that controls? A relay? Thank you, in advance!
wasaabi
Year and Model: ‘08 XC70, ‘97 965
Has thanked: 2 times
Been thanked: 2 times
Post by wasaabi »
In the manual it explains how to reprogram the key fob. I think it's to turn the ignition on and off 5 times within 10 seconds (not all the way to start, just off to on) then press the button. You may need to either leave door open or close door. Not sure. But it sounds like you need to reprogram it. Check the owners manual if you have it, as I know it's in there.
2021 XC40 Recharge P8 Twin Motor 48K
2008 XC70 193K
1997 965 155K "The 97"
1990 745 GLE 16-Valve manual + electric overdrive (sold 125K)
