92 940 Altenator Wire Route
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
rrussell
Year and Model: 940 92
Post by rrussell »
Does anyone know the route the smaller red wire on the back of the altenator takes? The diagrams I have lead me to believe this wire runs to the MCC unit on pin #8 (atleast eventually)? Does it go thru any other devices or junctions before then?
92_940_MCC_Circuit
92_940_MCC_Circuit
92_940_ChargingCircuit
I've been dealing with an electrical issue to the ac compressor. Had thought it was the MCC but the MCC is not reciving power on the red wire (#8) from the altenator. I ran a direct wire from the altenator to the MCC and the ac functions now via the ac switch on the MCC. BUT I cannot adjust the temperature via the dial, the ac continues to cool even if the dial is set to heat.
rrussell
Post by rrussell »
Just to follow up on this, my problem was a solder connection on the back of the instrument cluster where the circuit runs thru the charging dummy light.
