'95 Headlight Replacement Topic is solved
Guest
Post by Guest »
I've just replaced the driver's side headlight assembly (dual bulb, disagreement with a deer) my question is related to the spirit level built into the assembly, whats the trick to getting it to be level ? (one, cuz it bugs me thats its not and more importantly the alignment is way off in the vertical).
Jot
Year and Model: C30 2010
Post by Jot »
There are two adjustments which are plastic twist knobs. One is for side adjustment the other is vertical. Find a level parking lot where the other bubble is level adjust as the needed. When your car is in for state inspections that will set it.
