1999 V70 XC automatic gearbox fualt
dust
Post by dust »
My V70 1999 has a automatic gearbox problem. Ii has only 53000miles.I kinda felt the transmission wasn't shifting right while I was driving for about 4-5 month, today when I was driving the arrow light and check engine light which located under RPM gauge came on. But I could still be able to dri :cry: ve home. what cause this fault? anyone know? Is this just an electrical problem? will this cost alot to fix it? Still feel transmission shifting is not normal. I just afraid to go to dealer. They always charge way more than I expect.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2664 times
Been thanked: 1256 times
Post by matthew1 »
Check your transmission fluid (how to in owners manual). If it's brown or burnt smelling you should change it.
Also -> Amazon link
White850Turbo
Post by White850Turbo »
AutoZone can check your codes for free and tell you what's most likely wrong with it.
-Sean
1998 S70 T5 (Almost Stock)
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You likely need a new transmission position sensor (at best), a tranny at worst
