2009 XC60 Auto windows don't work anymore
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 2015+ XC60 2010-2018.
Tiny Tim 077
Year and Model: XC90 Volvo
Post by Tiny Tim 077 »
Hi all
Had to disconnect my battery yesterday for about two hours as I had to change my front lambda sensor and when I reconnected all works fine except for the auto up/down on all windows.
Is there a way to "reset" this function?
Thank you
dduk
Year and Model: V70 2.5T 2006
Post by dduk »
It should be in the manual.
Press and hold the window down button (but not fully depressed in the auto down mode) until the window goes down and continue to hold down for a few seconds. Repeat the same procedure to put the window up. The window should be programmed for auto down now.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
On P3 platform models you only need to roll the window all the way up and then hold the switch up for a bit over 3 seconds to reset the closed end point counter in door module.
Tiny Tim 077
Hi.
Sorry for the late reply. Thank you for the help, much appreciated.
