[b]Rear Window Washer on V70[/b]
This topic is in the MVS Volvo Repair Database » Learned the Hard Way: 1999+ Volvos Require Special Transmission Fluid
ohio tom
Post by ohio tom »
The rear window washer has stopped working on my 98 V70. I don't even hear a pump running.
All the fuses look ok.
Is the pump located in the :) right front fender in the same reservoir?
bill740
Year and Model: 2006 V70, 1990- 740
Post by bill740 »
location is in the same res as the front also common is the nozzle to clog their is also a ck valve under the plastic rear window arch directly behind the nozzle and may have a filter located under the right/pass side tailgate floor panel if the pump does not work repair that first than ck other items. note: ck valve has a small rubber like disc inside that some w/w fluid may melt causeing it to stop working their are also some of these located on the front for the front washers on the hood in your case.
fun to drive
