'99 S80 T-6 Torque for Crank Hub Nut etc
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
SimLyons
Year and Model: 2001 V70 T5
Post by SimLyons »
If anyone has the torque values for the nut on the front of the crank (big 30mm) and the 4 bolts holding the timing belt pulley on the hub please let me know. Thanks!!
Sim
matt5112
Year and Model: 1999 S65
Been thanked: 3 times
Post by matt5112 »
300 Nm (221 ft lbs) for the big nut.
Small ones are 35 Nm + 50* supposedly.
My understanding is if it has a spec then angle, it's a torque to yield bolt meaning it's a one time use.
SimLyons
Post by SimLyons »
Thanks! I've ordered new bolts. I was sure replacement was (is) in order. Do you happen to have the torque value for the hub nut?
Sim
matt5112
Post by matt5112 »
What I'm seeing suggests there should be one bolt that looks like this: http://www.ipdusa.com/products/6250/113950-axle-bolt
If so, 35 Nm then 90*.
The "upgrade" for reducing axle ping noise is this unit: http://www.ipdusa.com/products/6251/114 ... -anti-ping
Torque there is 50 Nm.
I've had one of mine out, but I can't recall if it's a nut or bolt.
