replaced knock sensors, won't run
butchwill
Year and Model: 1994 855T, 2006 C70
Post by butchwill »
I replaced knock sensors, cleaned Throttle Body and Idle Air Control. Now it cranks, starts and dies, if I give it gas it revs, pops and dies when I let up on the accelerator. Did I forget something?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Did you swap idle air control valve and throttle position sensor connectors?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Did you pull the manifold?
Has thanked: 1505 times
Been thanked: 3818 times
Intercooler hose is loose is my bet. Unmetered air running into the manifold and messing up mixture.
butchwill
Post by butchwill »
Yes, I pulled the manifold and used a new gasket. It is supposed to get up to 40 degrees on Saturday so I may wait until then to work on it again. Keep the ideas coming! I will take it all apart, except the manifold, and start over.
rspi
Post by rspi »
If the car is turbo, there is a chance that you got the corner bracket stuck behind the throttle body corner of the of the intake manifold.
butchwill
Post by butchwill »
Solved, I think. RSPI wins the prize. The bracket that holds the hose from the turbo to the PCV oil separator was between the manifold and the gasket instead of between the bolt head and the manifold. However yesterday when I read the codes again, I left the key on in the ignition and now will have to wait for the battery to charge in order to test. This simple project has been strung out for 12 days, but I'm not quitting until we solve it?
