2008 C70 How to replace rear shocks
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
whaitiri
Year and Model: S80T6, 2000
Post by whaitiri »
Thought I d share this with you all. The easiest way to remove the shocks is the following:
1. raise car and put stands under steel brackets just in front of rear wheels. Leave Jack under there to as a back up in case.
2. Remove wheels.
3. At the top of the shock is two 10mm bolts. remove these.
4. At bottom of shock is a bolt that holds shock to sub-frame. Its is 15mm. Remove this.
5. remove the shock through top of wheel arch.
6. replacement is reverse of process.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 36 times
Post by theWIFES_S70 »
Just replaced some shocks on my cousin's 07 C70. Pretty simply process. Took longer to jack up the car and line up the jack stands than to actually replace the shocks! Three bolts on each side. Bolts that attach the mount to the frame of the car have been redesigned. They screw up into the frame unlike the P80s that screw down and leave threads exposed to the elements!
There was no rebound in these shocks at 130K.
I followed the procedures in this father-son video on Youtube.
https://www.youtube.com/watch?v=QhdL6x1ouS8
Three bolts that popped off pretty easily: one 15mm on the shock to knuckle bolt and two 10mm shock mount to body bolts. Make sure to put on loctite when replacing bolts.
Retired:
2015 Volvo S60, T5, 85K
