S90- window driver side issue Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tampamatt
Post by tampamatt »
hi the entire mechanism for the window (motor and crank is off the door completely.does anyone have a diagram of just how this should be mounted? Is it best to disconnect the battery before going for this little adventure? Any advice?
It is apparent that someone has tried this repair as there where little bits of busted up pop rivets on the bottom of the door cavity.
Thanks
MAtt
