2003 XC70 Alternator Replacement/ bad bearing
anasvall
Year and Model: 2003 XC70
Post by anasvall »
I live close to a junkyard that has a salvaged 2000 Volvo S70 Sedan. Now my question is, although our cars take a 160 amp alternator, would my car run correctly on a 120 amp alternator without much trouble? I ask this because every part on the S70 looks to be in excellent shape and I'd rather go with OE than aftermarket for something like this. I done a cross reference of part numbers from advanceautoparts.com and found that the Bosch AL0805X 120Amp is used on the S70 and scrolling on down the 120/140/160 Amp listings for the XC70, I found that there is a Bosch AL0805X 120Amp listed as an "exact fit" for my car. The S70 is non-turbo 2.3, but appears to have the same flange configuration and same voltage regulator. Just thought i'd ask before I mess something up electrically. Thanks!
JDS60R
Been thanked: 3 times
Post by JDS60R »
Your only 15 min from a good re-builder. The 120 will fit and run but has less power to replenish the battery when in heavy use AC/headlights and blower fan on etc.
How much for the used one ( remember it has old bearings, regulator, brushes etc) ?
Retired
anasvall
Post by anasvall »
The used one will only run 20 bucks from the salvage yard. It has been sitting with nothing removed except the power steering pump that I previously had taken. The hood luckily has been shut the whole time since it has been here. The rebuilder says 148 bucks to rebuild the one I have. Refurbished one from O'reillys says 200 once my wholesale account kicks in (Toyota Parts Assistant Manager). I use my heated seats quite a bit but nothing else really.
JDS60R
Post by JDS60R »
Always nice to have an extra for 20 bucks. I would rebuild the old one in case I wasn't satisfied with the 120 or to have something when it dies. If the used one has more than 90K miles on it I wouldn't bother with the used one and just rebuild/have rebuilt the original one.
Retired
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Are you sure your XC70 has a 160A unit?
I did a crankcase vent system repair on a 2004 a couple of weeks ago and it had a 120A and was a cold weather package car.
JDS60R
Post by JDS60R »
My 04 xc has a 140 amp 0 124 525 029 and is cold weather pack
Retired
anasvall
Post by anasvall »
I'm not sure if my car does have a 160A unit or not. I was asked by volvo which one I thought it could be so I chose the highest of the 3. Hopefully mine is a lower amperage unit. How can you tell what amperage it has?
anasvall
Post by anasvall »
I just called volvo again and they told me it was a 140A according to the VIN. Would I be in too much trouble using a potential 120A unit?
anasvall
Post by anasvall »
my thoughts are that if your P2 XC had a 120A and basically all the XC's have similar equipment, I don't see why running a 120A alternator in a 140A config would matter. That's just me putting that out there. I could be completely wrong.
jimmy57
Post by jimmy57 »
The sizing of alternators is done based on idling charge level and not on full capacity. The full capacity is always overkill. The idling charge rate became important when electrical loads from gadgets and lighting got so invasive in cars. 120A unit has idling charge rate of about 70A as I recall and 140A one has 75A or so. If your car sees lots of short trips with headlights, wipers, fan, seat heaters, and rear window defroster + mirror heat then the 120A may not be enough. City livers and drivers are the ones whose cars would kill batteries in winter time with their normal driving routines before they started upsizing charging systems.
