Just like the title says. I am getting my brothers 98 v70r and he said it has a issue with the key now springing back from start. Can anyone point me in the right direction for repair?
I think he said he put in a new ignition switch already.
98 v70r. ignition key does not spring back
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
jasew503
- Year and Model: 1995 Volvo 850 Turbo
I had a problem with my 850 that was very similar, it wouldnt spring back all the way, abs light would stay on, headlights wouldnt come on, etc. I bought an ignition switch on ebay and replaced it which fixed the problem for me. (Not the key cylinder, just the switch which is on the back side of the key cylinder, easy to replace.)
mrjacobrussell
My brother seams to think the cylinder has the spring mechanism in it. I have never seen that in a car before and I have replaced a few ign switchs myself.
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
It's just the electrical part you'll need.
The general consensus is to blow a few
extra bucks on OEM. Check out Tasca:
http://tascaparts.com/partlocator/index ... eid=213668
mrjacobrussell
I should have the car in two weeks, taxes permitting. Before I Buying a new switch, if I pulled the switch off and turn it with a screwdriver will it springback on its own?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
- Been thanked: 504 times
The electrical portion of the ignition switch is on the left side of the steering column.
The spring mechanism that brings the key from position III (start) back to position II (engine running) is located inside the electrical portion of the ignition switch.
The tumbler (where you insert the key in) is similar to your house lock mechanism.
Not the same, but similar.
jasew503
The key cylinder probably wont spring back on its own without the switch, at least mine didnt, you may have to use the key to allign the switch and cylinder when installing it.mrjacobrussell wrote:I should have the car in two weeks, taxes permitting. Before I Buying a new switch, if I pulled the switch off and turn it with a screwdriver will it springback on its own?
mindshadow
- Year and Model: none
As others have said, you need to replace the electrical portion of your cylinder. The good news is that it's real easy to replace.
- 69 Replies
- 12537 Views
Last post by enotslim
- 505 Views
Last post by RickHaleParker
- 1293 Views
Last post by zanbringe
- 1074 Views
- 11 Replies
- 7968 Views
Last post by Ringo
