Volvo Experts
My car just started throwing a P0496 code - (Evaporative Emission System Flow During Non-Purge). I have cleared the code a couple of times but it seems to come back the next day. The Check Engine Light doesn't seem to come on while driving, only on startup - although once it's on, it stays on until it is cleared. Note that when I clear the code, I can turn the car off and back on and the CEL stays off. It's not until the next day that it returns.
I've read that this is a general code and could be a number of things. What is the most likely cause of failure? Faulty EVAP canister pruge valve?
I am a DIY-er but don't have an advanced scanner. What tests can I perform in my garage to nail down the cause of this?
Best regards, Kevin
2002 Volvo S60 2.4T AWD 296,000kms
2002 Volvo S60 2.4T AWD - P0496 purge valve Topic is solved
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
Code P0496 is equivalent to Volvo ECM 4007.
Here is what Volvo is saying about it;
ECM-4007 Evaporative emission (EVAP) system. Signal too high, B5244T3
Condition;
When the control module activates evaporative emission system (EVAP) control, the idle air trim or short-term fuel trim will change. Diagnostic trouble code (DTC) ECM-4007 is stored if the engine control module (ECM) does not detect any change in the idle air trim or in the long term fuel trim when evaporative emission (EVAP) control is active. The engine control module (ECM) interprets this as a faulty evaporative emission (EVAP) system.
Possible sources;
Open:
Faulty EVAP canister purge valve.
Closed:
Blocked hose between the EVAP canister and the EVAP canister purge valve
Blocked hose between the EVAP canister purge valve and the intake manifold
Fault symptom ;
Malfunction indicator lamp (MIL) lit.
In the following diagram it is item #16
The valve may be stuck.
Youtube is a good source of information on EVAP system's components and principles. Find here two examples.
This information should give you a good start to pin point the problem.
Condition;
Possible sources;
Open:
Closed:
Fault symptom ;
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
DGM
To test the valve you can apply vacuum using a hand pump to the perpendicular port. The meter reading of the pump should hold steady. You can listen to the other port if it is hissing when vacuum is applied. This would indicate a leak.
Also you can check valve operation on a bench with a small external battery, like a 9 volts DC. Look if it clicks. The vacuum should even out when the valve is activated.
If it is sticky, try a little bit of isopropyl alcohol through the ports with an on-off operation to remove dust/soot accumulation. You may save it this way.
It is component 8/18 in the following diagram. Note that fuse 11B/5 of the engine compartment is shared by many systems. See fuse description in the owner's manual.
I pulled the EVAP canister purge valve and hooked it up to a fresh 9V DC battery. There is no clicking when I applied the 9Vs to the purge valve. I assume this means the valve is stuck. I can't blow through the valve so I assume that if it is stuck, it is stuck in the closed position.
Does this conclusively point to the purge valve failing and likely casing the P4096 code?
Thx, Kevin
Thx, Kevin
Kevin
Kevin
UPDATE:
I replaced the canister purge valve and the Check Engine Light no longer illuminates and there are no OBD II Codes.
A $60 part and 20 minutes to replace looks is all it took to fix.
Thanks for everyone's help.
//Kevin
//Kevin
Kevin
Kevin
- 7134 Views
- 2267 Views
Last post by Tompolish
- 11 Replies
- 4110 Views
Last post by Brianvzyl
- 1648 Views
Last post by bmdubya1198
- 7360 Views
Last post by Seaway
