1993 940 Cylinder head has some plugged holes?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
I can see what looks like factory plugged holes on the bottom of the cylinder head. and the gasket matches up perfectly to cover those certain holes. is this normal? I mean, the holes literally look like caked up carbon, but when I chiseled at it with a flathead and a rubber mallet, it doesn't flake away like the rest of the caked up carbon I already scraped and chiseled away in other areas of the head. So again, are these holes suppose to be sealed up like that? :shock: :?
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Quite normal. That head could be used for different engines and need the closed holes open and the open holes closed. Depending on its use depends which holes are drilled out.
I do hope you didn't use a chisel on the head as even minor scratches can be bad. Have you checked the head to see if it is of the correct height or warped? This is essential whenever the head is removed.
The head height should be 5.752" (146.1mm) You can check warpage yourself using a metal straight edge. Check both crosswise and lengthwise. Maximum warpage allowed is 0.02" (0.05mm) crosswise and 0.04" (1.0mm) lengthwise. If it exceeds either of these measurements the head must be skimmed before refitting.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
98T5
Post by 98T5 »
billofdurham wrote:Quite normal. That head could be used for different engines and need the closed holes open and the open holes closed. Depending on its use depends which holes are drilled out.
Bill.
:o :shock: I have not done this step, but in the interest of time and money, I will have to do it myself. hopefully it's not warped. As I can't afford to have it skimmed. :x
And I did use a flat scraper and green scrub pads to get the heavily stuck old gasket off. the valve gasket was a total PIA to get cleaned off good. the rest of the areas like the manifold, head gasket, etc..cleaned up quickly. not shiny silver, but clean enough from the build up and gunk. I'm not trying to win any shows with this car, it's a daily cruiser. I just want it running again with no leaks. :mrgreen:
