I have noticed that my car is using a bit more coolant than it has in the past 3 months and sometimes there is a wet spot under the passenger side engine area. I haven't had an opportunity to really get in there and pull the wheel. Could this be a water pump leak? I keep feeling like the PCV needs replaced which I am the process o making happen. If this is the case, could this force a leak of coolant?
Thanks
98 V70 GLT coolant usage and spot under right side
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
Check the simple things first. Inspect tank and hoses. Had the similar problem on one of the V70s. the bottom hose was torn. We also replaced the two small coolant hoses on the backside of the motor.
stephansvolvo
Cool. I'll check that. I think I did but if I can't remember I might not have.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
stephansvolvo
Thanks Robert! And I liked your response as I appreciate your warnings and videos.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
