1999 XC70 key doesn't go in ignition completely
Jack Rock
Year and Model: 1998 V70R
Post by Jack Rock »
New to me XC, the key doesn't go in all the way, the tumbler turns no problem and car starts up just fine. However, the key can be removed in any position. I can also start it with anything flat really as long as the key is nearby. I've read about some issues with the ignition switch but this sounds like a key tumbler issue right? If so, I suppose that's a dealer job in order to program the keys/immobilizer? I would leave it but I also can't lock my doors because it thinks there is a key in the ignition and keeps unlocking itself. Thanks for any advice.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Yes, that's the tumbler assembly.
The keys/car will NOT need to be reprogrammed if you order an ignition collar that fits your existing key (they will match it to your VIN number).
'98 S70 T5
2016 Chevy Cruze Premier
Jack Rock
Post by Jack Rock »
That sounds like great news, thanks. Is it a hard job to swap it out? I guess it's safe to assume that I will have to order that ignition collar at a dealer right?
1999 V70XC
1975 VW beetle
jblackburn
'98 S70 T5
Jack Rock
Post by Jack Rock »
Wow! I think it's safe to assume that if I can't find something here, I didn't look hard enough. Thanks a lot.
1999 V70XC
1975 VW beetle
Jack Rock
Post by Jack Rock »
Just to close this off... I bought a barely used tumbler from cn90 and installed it with the same results, turns out the plunger in the center of the ignition switch was preventing the key from going in. I replaced the ignition switch and solved the issue. Sure glad I didn't spring for a new tumbler at the dealer $$$
1999 V70XC
1975 VW beetle
Has thanked: 1505 times
Been thanked: 3818 times
Jack - is this the same car that is having alarm trouble..????
10 meter penalty for withholding information if it is....
:lol: :lol: :lol:
Jack Rock
Post by Jack Rock »
:oops: Um... yes but I discounted them as being related after much thought because the after I got the ignition/key working properly, the alarm tripping is still a problem. I waited to post the alarm question until after I fixed the key problem.
... and I thanks for noticing my patriotic commitment to the metric system :mrgreen:
1999 V70XC
1975 VW beetle
I'm thinking these two problems are related somehow. Maybe the immobilizer ring is FUBAR or there is a bad connection in the plug?
