2008 XC70 Brake Lights
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
gmuree
Year and Model: 2008 XC70
Post by gmuree »
Hi I have a 2008 XC70 that has a problem with the brake lights. When the brakes are applied the brake lights on the hatch light up but not on the body of the car, but if the hatch is opened up the brake lights go out on the hatch and the brake lights light up on the body of the car. I only noticed this after I had picked up a camper trailer that had a round 7 pin trailer plug. As I only have a flat 4 pin plug installed on the car I bought a conversion plug that will connect a 4 pin flat plug to a 7 pin round plug. I checked the voltage in the 4 pin flat plug and there is no output when the hatch is down and there is when the hatch is up. I went back to the store that did the hitch and wiring install and they tried completely removing the trailer wiring and the problem still exists. I don't know how long this problem has been there as I only checked it after I hooked up the trailer. I have owned the car since 2010 and the hitch and wiring were installed in the fall of 2010. I have only towed a ski do trailer which uses a 4 pin flat connector 4 times since this was installed. Also there are no messages on the dash indicating anything is wrong.
Thank you in advance for your help
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Has the car been scanned with VIDA to see if there are codes?
There could have been some crossed wires during install of the trailer wiring that set code in lighting control (CEM). OR do a battery reset.
gmuree
Post by gmuree »
Thanks for your response Jimmy. It hasn't been scanned yet. I do have a scanner which I will use. The trailer wiring harness has now been totally removed and this problem still exists
