1997 V70 Won't even turn over.
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 14 times
My car was running sort of fine - some slight hesitation as of late - then after a short drive of a few miles, I parked the car. A few minutes later, I needed to move it out of the driveway and it would not start; not even a click. I did notice the oil light on the dash stayed on after I turned off the car. I recently changed the oil and oil filter. Any ideas what this could be? Starter cables; dead battery; oil pressure switch? Will charge the battery in the morning and see if the car starts. Appreciate any suggestions.
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Batteries the first place to start for sure. Check fuses, relays and cables.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- Has thanked: 1505 times
- Been thanked: 3818 times
Lights on at funny times is often bad grounds. These cars are known for developing bad braid wires grounding battery and engine to chassis. Somewhere there are posts depicting all the grounds in the engine compartment - there are a lot of them!
I live (weekends) about 5 minutes from a 5 rivers in upstate NY...PM me your location (button on right) in case we are neighbors!
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
The oil pressure light on this car is stone simple.
There has to be voltage present for that lamp to light.
And it also sounds like parasitic draw has been an issue.
I'm puttin' my money on the ignition or an overload relay.
