2000 SE70 Transmission
I own a 2000 SE70 (AT) with 85,000 miles. On a cold start the gears all change smoothly except when going from 2nd gear to 3rd gear. When this happens, there seems to be a sudden urge for the car to get to the 3rd gear quickly and/or a slight jarring feeling that the car produces. Once the car has been driven, warmed up and gone thru these gears a few times, then all is fine. This only occurs between the 2nd and 3rd gear shift. Thanks for your help. obri
My 2000 SE70 (AT) is jerky and unsmooth between the 2-3 gear shift. After the car is warmed up the 2-3 shift is fine. All other gear shifts are excellant all the time. Any ideas? obie
- 1211 Views
Last post by alschnertz
- 1448 Views
Last post by foggydogg
