2000 S70 Shaking front end
gsheffi
Year and Model: 2000 S70
Post by gsheffi »
Front end shakes terribly between 50-65/70. smooths out past 70 & rides great.. have replaced tire rod ends, shocks, struts,brake pads, rotors, 3 Engine mounts & had a Volvo 4 Wheel alignment done. Tires are good... "Driving me crazy"............
Has thanked: 1505 times
Been thanked: 3817 times
How many miles are on it and how many miles are on the lower control arms/ball joints?
gsheffi
Post by gsheffi »
215K.. unsure of mileage on l/control arm/ball joints. Owned for 4 years Great condition, 1 Owner Haven't replaced 2 items mentioned.
On good roads you might get 150k miles out of OEM ball joints and control arms (they come as a unit) but bad replacements can last as little as 20k
Try moving wheels around, front to back.
You can also jack wheel up and check for play at 12 and 6 o'clock for ball joint wear
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Google Hunter Road Force balance and see if you can find a local shop. That will help id a bad bead in the tire or a slight bent wheel.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
Thrown a wheel weight?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
mastermoder2
Year and Model: s60 2.5t 2004
Post by mastermoder2 »
My 04 s60 2.5t is doing the exact same thing some days the vibration shaking is much worse than other days. I was reading that the CV shaft might be to blame. I don't want to have to replace all the stuff you did before finding out the problem only because I'm trading the car in or selling it so I can. Get me an s60r of the same year.
gsheffi
Post by gsheffi »
I replaced the R/L lower control arms & the right axel, which was bad. Rides/Floats like new. Thanks so much.
