1999 S70T5. "Click" followed by small upsurge in idle.
ThinAir
Year and Model: 2005 V50 T5
Post by ThinAir »
Hey everybody,
OK, so just recently the S70 has started to randomly emit a single "click" sound from the engine bay followed immediately by a small (200-300 rpm) surge. One does not seem to happen without the other. I have quite recently replaced the ETM with a Xemodex unit and I have also replaced the MAF, ignition coils and Evap purge valve. In the 10,000 mile I have driven this car I have changed oil every 3500 to 4000 miles. Weird. Thoughts please!
J
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
When the AC compressor comes on it clicks and is often followed by a surge in RPMs,
ThinAir
Post by ThinAir »
Hmm. I will check this out tomorrow. Thanks Polska. The strange thing is that it happens regularly as I drive along. Why would the AC keep turning on?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1242 times
Post by matthew1 »
Howdy Thinair!
Yep, AC. Normal, unless it's frequent, in which case the R134a needs a charge.
Also -> Amazon link
polskamafia mjl
+1
AC compressor clicking on and off is a classic symptom of low R134A in the system.
ThinAir
Post by ThinAir »
You guys are the best! This is a bit annoying though as I never use the AC. So I will be recharging it just to get rid if the clicking. +1 for Polska and Matt.
J
polskamafia mjl
If that's the case then you can turn the AC off. On the climate control panel flip the AC switch to off. It is right next to the REC switch.
ThinAir
Post by ThinAir »
Yep. So I was running the defrost to try and heat up my squeaky dash. Thanks for the help guys. Knowing is half the battle.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
ThinAir wrote:Yep. So I was running the defrost to try and heat up my squeaky dash. Thanks for the help guys. Knowing is half the battle.
Have you tried shoving things around the mounting points near the windshield?
I cut up a cheap rubber mouse pad and shoved it in some of the corners - helped immensely with the squeaks and rattles.
'98 S70 T5
2016 Chevy Cruze Premier
ThinAir
Post by ThinAir »
Hey J,
This will be my Memorial Day project. I will check the firewall mounts and then try your mousepad fix. Man, it has gotten really bad. The plastic strip right below the windshield is cracked in three places as well. Thank God these cars came with a loud stereo! Well, I will report my findings in any of the fine "My dash is squeaky as hell" threads here at MVS.
Jeremy
