Hey everyone!
So i think my lack of sleep is keeping me from thinking clearly, but there is a rubbing sound coming from both rear brakes, I have removed the calipers and turned the rotors by hand and it sounds like its rubbing against the dust shield but i can not see where.
first that comes to mind is parking brake pads, i have adjusted them all the way in and even removed them completely with no change, is it possible for both rear hubs to be bent? my other thought was to remove the dust shield but i need to pull the hubs. to get the shield off...
98 S70 T5 Rear brakes rubbing?
Glencoeteen
- Year and Model: 00 V70R
98 V70XC~ Sold
98 S70 T5 ~ Stolen ;(
08 Xc90 V8 ~ Totaled
98 Expedition EB weekend warrior
98 S70 T5~ New project!
- Has thanked: 292 times
- Been thanked: 765 times
Does sound like a dust shield(s) but here's a place to look if you haven't: When the drum is off, and you spin the hub, is it smooth and quiet (it should be, of course)? If the e-brake hardware is pushed out of place it can rub on the hub inside of the drum; I think it is the lower spring gets hung up.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
Glencoeteen
hub spins great, no play or noise. only once i install the rotor does it make that obnoxious sound, i removed the ebrake pads, springs and spun the rotor still same sound, i think i will pull the hub, remove the dust shield and see if there is a difference
98 V70XC~ Sold
I'm stumped for other than dust shields I feel your pain ...
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- phils94850
- Year and Model: 2009 s60 turbo
yep.. sounds like a dust shield
1996 Platinum Edition
- Has thanked: 1502 times
- Been thanked: 3817 times
Could it be a bad wheel bearings? Unlikely since it is on both sides, but......
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
I spent 2 hours Wednesday searching for the source of the SAME EXACT sound you are hearing (probably).
It is the portion of the dust shield that the caliper mounts over - pry it back and forth while you spin the rotor. I got the noise to go away, but after putting everything back together, it came back. I gave up.
Mine only scrapes for a small arc of the full rotation, which made me think either the hub or the rotor was out-of-round. Hub is perfect (just replaced the wheel bearing on that side, too), and I couldn't feel any bumps on the rotor (not exactly a precision check, but the Zimmerman rotors only have 5k miles on 'em).
So, while driving there is a Shhhk ..... shhhk ..... shhhk. Annoying.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
Glencoeteen
well i know its the dust shields, i ummm errr, i got a little angry and took my 5lb hammer to them... work stress and the fact that this car has been one thing after the other i decided to do it Jeremy Clarkson style ( I love Top Gear UK ) plus side when i am done with this project everything will be new and my wallet will be buried in the back yard with a cross
98 V70XC~ Sold
- 2213 Views
Last post by other_shoe
- 662 Views
