1998 v70 GLT Code P0413 - Check Valve? Air Pump?
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
I am getting code P0413 on my OBD II scanner and after searching endlessly, I don't know what I am supposed to replace? The air pump itself (seems as though that is code p0410), the air pump control valve or the air pump check valve (black and white check valve). Does anyone have any ideas? I am willing to replace all three if needed, but I can't seem to find an answer. I am in Virginia, and will need to have the cars emissions tested, so the SAS delete does not appear to be an option.
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Seaway
Post by Seaway »
I read that post in my search. I will see if the pump is running and if so, I will check the connections and work from there. Coming from a Mercedes background, I am still learning the ins and outs of these cars.
Thanks.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1240 times
Post by matthew1 »
Seaway, welcome to MVS.
This might help also 1998 V70 AWD P0455 P0440 P0442 Fix with Photos.
When/if you have time, I'd love to hear your thoughts on DIY MB vs. Volvo. Start a new thread for it.
Also -> Amazon link
Seaway
Post by Seaway »
Thanks for the welcome. I will start a thread about MB diy vs Volvo tomorrow when I have a chance.
I am hopeful that I can get this issue with the air pump resolved soon as I need to have the car inspected by the end of the month. Other than this hopefully small issue it is a wonderful car. 215,000 miles and runs and drives great. The exterior has some bumps and bruises but the engine is in great shape with many new parts and all of the standard stuff up to date. Doesn't leak a drop of oil (unlike the three Mercedes I have had). The only code I am getting is the P0413 when I hook it up to the code reader. My inclination is to replace the parts associated with the air pump and move on from there as I will then at least have baseline.
Thus far I have just done the air filter, oil change, spark plug, cabin air filter and the resistor for the AC blower motor. Plug wires and distributor cap are next on the list. I will say that it feels more solid than the Mercedes I have had, but none were newer than a 1988. I have had a 1982 DL Sedan and a 1987 GL wagon and I am glad to be back in a Volvo.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
https://www.matthewsvolvosite.com/forums ... 24#p329524
Replied to something similar earlier this week - this post might help check the circuit.
The main fuse compartment at the windshield cowl has a few Torx screws around the edges - the cover will come off to reveal some relays. The air pump relay is the one closest to the front of the car if I recall correctly.
'98 S70 T5
2016 Chevy Cruze Premier
Seaway
Post by Seaway »
jblackburn wrote:https://www.matthewsvolvosite.com/forums ... 24#p329524
Thanks! I will check this as well.
