1999 ---> 2.5T Oil Filter Tool recommendation
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
Hi guys,
For 1999+ models (S70, XC70, XC90 etc.) that use Plastic Oil Filter Cap, what is the best tool that you guys like?
I came across a few options:
CTA A261 ---> $3:
http://www.eeuroparts.com/Parts/8184/En ... ench-A261/
FCP Euro CTA-2489 ---> $10:
http://www.fcpeuro.com/products/volvo-h ... tools-2489
Assenmacher Specialty Tools V 410 ---> $16:
https://www.amazon.com/Assenmacher-Speci ... B000XML6DU
And of course, the Volvo OEM Tool for $36:
http://www.ipdusa.com/products/7530/113 ... cap-wrench
blandis
Year and Model: 99 S70 T5
Been thanked: 3 times
Post by blandis »
I have the el-cheap-o one. On our XC90 have to put a shop towel in it to get it to bite. On my s70 no issue.
I saw no reason to spend any more money than the $3 one when I only use it a couple times a year.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
Volvo dealer sells AST V410 wrench as "volvo tool 9995679", IMO this is the one to get if you want to properly torque the filter and not replace filter holder too often.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I have the Assenmacher version. It has worked flawlessly but then again the $3.00 versions may work just as well.
Post by cn90 »
The Plastic Oil Filter Cap ($22 at dealer): do you guys ever replace this plastic cap?
In my 1998 BMW 528i, it cracked at 10y/100K or so. Luckily, it was a tiny crack that allows to seep out slowly. I replaced it.
Back to the Volvo, I wonder if this is cheap insurance to replace this thing every 9-10y/90K-100K?
confused_al
I have 110k on my 2006 still use the one from factory.
98 MB ML320
06 V70
95 850 GLT(RIP)
Post by Ozark Lee »
I bought one when I installed the replacement engine in the XC. I managed to chew the original up pretty good when I removed it with some vice grip type oil filter pliers and the cannister on the replacement engine came out of a wrecked car and it had a giant dent in it from the wreck.
Post by cn90 »
A little update,
I have both the Assenmacher V410 and Lisle 61660 86mm 16-Flute Tools: $16 vs $8 comparison...
You can read amazon reviews, and this is my review, which is similar to amazon reviews...
- The Assenmacher V410 is well constructed (Aluminum) and fits the oil filter cap tightly. It is a bit difficult to separate it from the cap once installed, but wiggle a bit, it will come out. BEST is the leave the cap attached to the tool during removal, then install it, followed by wiggling to separate them.
- The Lise 61660 tool is also well constructed (Steel), the welds are very strong. It is a tiny tiny bit more "loose" than the Assenmacher. The trick is to add a bit of paper towel or a bit of rubber glove to make it fit tight, but this is a bonus, you don't have to do it unless the oil filter cap is on VERY TIGHT from the previous oil change gorilla.
Whatever you choose, both are very very good tools...
- The Assenmacher requires a 21-mm socket/wrench...
- The Lisle tool requires the standard 3/8-inch drive...
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
The Lisle 61660 86mm/16-flute fits conveniently both our volvo XC60T5 and BMW 335i - no need for towels :D
(bought a while ago on sale don't remember exactly for something $12 delivered)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
