My 96 850 Turbo is about to cross the 200k threshold.
She already needs a blower motor and some suspension work.
What other investments should I prioritize at her big birthday?
She is a daily driver and stands up amazing well, and looks really good for her age.
Someone took care of her before I got her a couple years ago.
1996 850Turbo 200K Advice
thedancingfiddle
- Year and Model: 1997 NA 850 wagon
When is the last time the timing belt/water pump were done? Could be time.
Also, how about cleaning/replacing the PCV system? Definitely a good thing if you've never done it on the car!
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
With a 18 year old high mileage car I would look at items that could kill the car. What comes to mind is the cooling system pump and hoses, PCV, timing belt, oil lines and transmission fluid change. I think addressing these items you can easily punch out another 100K.
thedancingfiddle wrote:When is the last time the timing belt/water pump were done? Could be time.
I am really not sure when the timing belt was done, like I said it is only two years with me. You are probably right, that the belt and pump combination should be done PCV, okay.
Thanks for the ideas
Brad
850T
850
244
244T
850T
850
244
244T
I thought about transmission fluid change, but I have heard stories of auto transmissions that stop working after a fluid change with high mileage, maybe that is urban myth. Yeah, the car breaker things make sense, I wonder how much it would be get all the lines.kahl wrote:With a 18 year old high mileage car I would look at items that could kill the car. What comes to mind is the cooling system pump and hoses, PCV, timing belt, oil lines and transmission fluid change. I think addressing these items you can easily punch out another 100K.
Yeah, I love this car, how she feels on the road still, I would happily keep her another 100K
Thanks Kahl
Brad
850T
850
244
244T
850T
850
244
244T
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
if you don't know when a timing belt with a 70,000 mile change schedule was done, then it was done 70,001 miles ago
transmission fluid flushes as performed by auto mechanics can be hard on the transmission. a couple of drain-and-fill cycles is the preferred method and won't do any damage.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I have changed the fluid in my transmission 3 times (3 drains and fills each time, every 25,000 miles). The last was today.
Do you do your own work?
thedancingfiddle
You should get it done asap! Water pump, tensioners, pulleys as well. The whole job.brad850 wrote:
For the PCV, also probably a good idea - if you see any oil leaked out around the fill cap and around the valve cover, it is a pretty good sign that the PCV is clogged.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
I'd change both O2 sensors right away. A failing sensor can lead to a burned valve or a trashed catalytic converter -- neither of which are cheap fixes, especially if you don't do a lot of your own work. They are maintenance items at 100K miles.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- 619 Views
Last post by phils94850
- 655 Views
Last post by MoVolvos
