Good People,
Which cylinder heads are compatible with my 98 V70 XC?
Thanks,
John
1998 V70 XC Cylinder Head Compatiblilty?
- Has thanked: 293 times
- Been thanked: 765 times
Heads from these engines will swap right over, with no modifications:
95-98, any high pressure turbo (2.3 liter engine, all T5 models)
97-98, any low pressure turbo (2.4 liter engine, 97 and 98 GLT models)
So any 95-98 turbo, either HPT or LPT, they all use the same head. Non-turbo heads will fit but the don;t have sodium filled exhaust valves and apparently Volvo thought that was important.
A 94 turbo head will work but you may need to get the intake manifold too; easier to stick with 95-98. I also think the 99+ heads will work but not without modifications and I am not familiar with those.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1507 times
- Been thanked: 3822 times
99+ heads bring in variable valve timing (CVVT) which is a big complication.
- 1885 Views
Last post by precopster
- 13 Replies
- 7717 Views
Last post by lifeofgold
