1996 850 Turbo Glove box light removal
jgc470
Year and Model: 96 850T 96 855R
Post by jgc470 »
I have a short in my 850's electrical system (it's drawing .70 amps), and have trace it down to circuit 15 (the system draws only .06 amps when I remove the fuse). This circuit consist of: courtesy lights, keyless entry unit, onboard power for code reader, and the glove box light.
I have removed the glove box and have access to light unit, but how to properly remove it, to test it, is not intuitively clear. Any suggestions ?
Plus any suggestions or aid on keyless entry box would be helpful. It is in the same area and I will hit that next if glove light unit is not the issue.
Thanks
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I'm not sure what you are asking. The glove box light is simply a socketed lamp with a hood. The keyless entry receiver is to the right of the glove box on the A pillar and it has a green colored connector.
jgc470
Post by jgc470 »
Thanks for the response, I am not clear on how to remove the light unit. Is the hood of the unit, which accesses the blub, spring held or screwed in place? Is the push button part of the unit held in place by a clip? I have not removed the dash top, so I do not have a clear view of it. The unit itself appears to be molded in place to the upper dash , so wish to have a bit information before I use brute force.
jgc470
Post by jgc470 »
I removed the light unit and provide the following information for the record. The unit is held in place by a set of saw teeth, one above and one below. When made, the unit was set by pushing it from the back of the dash towards the front. This way when the glove box door strikes the unit it "digs" into the dash and holds it in place.
To remove it requires a small flat face screwdriver to pry the teeth from the dash and a mirror so you can see what you are doing, then push it out towards the engine. The hood is held on by it's driver's side saw tooth, and can be pried off.
jgc470
Post by jgc470 »
As a final note, I finished removing light holder and testing it for the short. It was not the problem. I failed to mention that to access the light or light holder, you must remove the inner (Glove) box. I used Ozark Lee's write up on "Glove Box Removal", which explained the how to do. The short was in the keyless entry module which is under steering column.
floodcity1
Year and Model: 1997 850
Has thanked: 1 time
Post by floodcity1 »
jgc470 wrote:As a final note, I finished removing light holder and testing it for the short. It was not the problem. I failed to mention that to access the light or light holder, you must remove the inner (Glove) box. I used Ozark Lee's write up on "Glove Box Removal", which explained the how to do. The short was in the keyless entry module which is under steering column.
Please help, and advise: just where, under the steering column on a '96 850 Turbo, is the keyless entry module? I'm aware of the receiver on the A-pillar behind/to the right of the glove box insert, but not this "module". Could this (instead) be the circuit relay that is being referred to?
Mark Mc, Loganville, Georgia, USA
1997 850 Base sedan - 103K, current project
1996 850 T5 Platinum Edition sedan - deceased
1997 850 GLT sedan - deceased
noev70t5
Year and Model: 1995 850 TURBO
Post by noev70t5 »
You have to push the bulb in a tiny bit and twist
2002 s60 Base - 215k - KIA [08-2014]
2000 s70 Base - 170k - Traded in [2015-16]
1998 v70 t5 - 232k - KIA [2016-2018]
2000 s70 Base - 180K KIA [2018-2018]
1995 850 TURBO - 77K [2019-]
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
this os a 6 year old post that was solved back then.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 1500 times
Been thanked: 3812 times
We are very patient here in the States. It comes from our long history.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
There you go Abs!!! I got a chuckle at that one!
