Like the title says, how do you remove the trailing arm bushings?
I had one done by a mechanic in '06. They used an air hammer do smash it to bits...then they replaced the right side unit with a left side bushing!
Well, my left/driver's side bushing is broke, and I also replaced the right side bushing with a proper one. These things are tough to get out. After breaking both bolts off because they have frozen solid in the aluminum, I used a sawzall to cut off the rest of the bolts off.
Here's one thread showing my delta links debocle and the new right side trailing arm bushing,
https://www.matthewsvolvosite.com/forums ... =1&t=64918
and another thread showing my busted driver's side bushing,
https://www.matthewsvolvosite.com/forums ... =1&t=65017
96 850 How did YOU replace the trailing arm bushings?
- 2953 Views
Last post by 800artfreed
- 2909 Views
- 434 Views
Last post by alschnertz
- 999 Views
Last post by bkw1962
- 11 Replies
- 10515 Views
Last post by BlackBart
