2001 v70xc Turbo Concerns ... I need help!
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
larrycrilley
Year and Model: v70xc 2001
Post by larrycrilley »
The turbo wash not been kicking in...I got a code to change the turbo control valve which I did and it did not make things better. Recently, during acceleration it has been putting out some smoke which does clear up at cruising speed and I had to add oil with no visible leak. It is now throwing a code for a bad boost pressure sensor.
My question is - Could a bad boost pressure sensor be the cause of the oil burning smoke or do I need a new turbo charger.
Thanks in advance.
Larry
PS - I did purchase a DiceVida and the software it came with has been driving me nuts. I am expecting new software.
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
It sounds like air leaks and oil getting in intake mani. I'd check the PCV system and leaks at turbo shaft.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
