'96 960 volvo P0172
'96 960 volvo P0172
Code above comes on despite 02 sensor replacement, air injector valve cleanout, spark plugs, intake manifold cleanout via vaccuum line, MAF swap, idle motor swap. No obvious vaccuum leak!. Barely passes NOX and HC. Freeze frame on O2 sensor is working Is vaccuum leak the most likely problem. otherwise car runs great. mel
- 1324 Views
Last post by henrysin44
- 707 Views
Last post by rspi
