1999 V70 bumper paint
buffmont
Year and Model: 1999 S70
Post by buffmont »
Hello, About to repaint the front and rear bumper covers, I understand you have to use plastic bumper paint.
Anyone have experience or recommend a particular brand ?
Heard about SEM but they dont seem to have Volvo colors ?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
If Black or White color, then it is easy, any other color is a gamble (ask local shop to blend the color for you).
I have Black car, so I bought standard paint can (gloss fits better than matte, although I have used both).
I think I bought Duplicolor (? spelling) brand.
The key thing is prep work:
- Sand
- Fill any defect with Bondo.
- Masking Tape any area you don't want to paint (lift the hood upward etc.).
- Spray evenly.
- Best is to do this with temp > 10C
- Do this inside a garage, you don't want the wind to blow crap on your paint work.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Don't forget you need a paint that has flex additive or one tap and it will blow right off
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
Use an adhesion promoter too as I had trouble where the filler caused the primer to pull off in a sheet- this was after I asked the paint guy at Napa if I needed it, worst thing was I had the stuff just didn't use it I also used some SEM texture at the bottom of the front bumper to cover up all the scrapes and divots that had developed over time
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Be careful with white. Do some test pieces beforehand. An ill-matched white will look worse than a chipped-up bumper, IMO, and white is not just white.
I've used paintscratch.com to get paint that's mixed to the original factory color, and it's a pretty close match. Autozone &c also carry matching paints for some makes and colors, which are okay, but I haven't seen any for Volvo.
