Hey guys
Starting a new thread with a few simple (hopefull) questions about my manual swap (which is off the ground and going quite well!)
1) The donor car had the old style abs module setup and my 97 has the new one. Will this impede my ability to fit the clutch master cylinder and clutch hose? as far as i can see there is only one type of hose available so im guessing it should be ok.
2) I have the manual computer to replace the auto one (yay for entire donor cars) Is there any special wiring im going to need to do? Considering there is a huge plug for the auto from the wiring harness that is not gjoing to get used. Plus the pnp switch and the back up light.
3) the auto has magnetic drain plugs and the manual doesnt. should i switch them over?
Thanks
Nick
Re: 95 to 97 850 manual swap question
dairyqueen814
- Year and Model: 1997 855 NA
1994 850 Sedan NA Black, 343,000mi - Crashed and parted
1993 850 Sedan NA Red, 240,000mi - Now my little brother's car
1994 850 Wagon NA White, 251,222mi - Sold
1997 850 Wagon NA Red, 105,000mi - Currently my pride and joy
- Year and Model: Many Volvos
- Been thanked: 76 times
I think it is all the same as far as the hoses go. My 5 speed is a '94 with the early ABS system and I have never really compared that area of the firewall with my later model automatic cars. If by chance I am under the hood of the two cars I will look to see anything that raises a red flag.
Was the manual car (95) ECU a Motronic with a single module or the Jetronic with two modules? On your '97 you almost certainly have a Motronic module. If the donor car module is a Motronic then you should be well on your way but there were some EGR and SAS differences between model years and even some geographic destinations that might need to be sorted out. If the donor car had a Jetronic system then your path of least resistance is going to be to send Lucky at ARD your '97 module to get it reprogrammed as a manual transmission ECU rather than trying to swap out the entire wiring harness.
The the magnetic drain plugs can't hurt anything so long as they aren't too deep and bump into the internals but they really aren't necessary. The manual transmissions don't generate fine metal shavings like the automatic transmissions do. If there is metal floating around in a manual transmission it is usually big pieces, like teeth off of gears, and the magnet won't help you.
dairyqueen814
both cars have 2 modules in the black box above the washer fluid reservoir with one empty slot. is one for the engine and one for the tranny? i was always confused about what they did. should i contact lucky? i was under the assumption that the middle module just swapped out but thats why im here!!Ozark Lee wrote:Was the manual car (95) ECU a Motronic with a single module or the Jetronic with two modules? On your '97 you almost certainly have a Motronic module. If the donor car module is a Motronic then you should be well on your way but there were some EGR and SAS differences between model years and even some geographic destinations that might need to be sorted out. If the donor car had a Jetronic system then your path of least resistance is going to be to send Lucky at ARD your '97 module to get it reprogrammed as a manual transmission ECU rather than trying to swap out the entire wiring harness.
Thanks
Nick
dairyqueen814
Also
I have done the sas delete on my 97 where you solder 2 pins together in the module if it is relevant information
The modules from the '95 are both ECU modules. There is a fuel system module and an ignition system module. On the '95 donor car there is no transmission module since there is no automatic transmission. That car has the Jetronic LH 3.2 system. On your '97 you also have two modules but one is the Motronic ECU (fuel and ignition combined) and the other is the TCU for your existing automatic transmission.
The two systems are largely incompatible. The wiring harnesses are different and some of the sensors are different. I know for sure that the MAF is different. Those differences also extend into the cabin.
Lucky should be able to flash the ECU with the proper manual transmission parameters or you might just be able to find one on ebay or in a junk yard. The latter will be the cheaper option. They are fairly rare but available I would also try Erie VoVo and Tom's Foreign since they both run through a ton of Volvos for salvage.
You should give ARD a call and make sure that they have N/A - manual code. I know he has turbo - manual code and that is a place where it is really your only option since those modules were never available in the US. My guess is that he has the N/A code as well and it won't be a problem for him. Lucky or Michelle can give you a price for the service. At that point you have a price reference and you can shop for the best alternative.
The last option is to simply keep your existing ECU and live with the CEL. If it were just the CEL that wouldn't be a terrible option for me since we don't do any kind of inspections in my area but there are also some less than optimum throttle response issues like the way the engine throttles back as you go between gears.
dairyqueen814
What would I want to be looking up if i were to buy a used core?
dairyqueen814
Im on there right nowOzark Lee wrote:I would also try Erie VoVo
Does this look like what i want?
1997 VL850
Brain Box FUEL INJ. 261203076-FF.2 Electronic Control Module, (right hand front engine compartment), without turbocharged, 4 valve, manual transmission
- misha
- Has thanked: 155 times
- Been thanked: 432 times
This might help:
http://www.boschecus.com/bosch-02612030 ... m4-4-1-ecu
According to Bosch numbers you provided in previous post,that ecu is Motronic 4.4 management.
Since your is also '97 it should also be Motronic 4.4.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The description sounds like exactly what you need but I'm not familiar enough with the actual part numbers to verify that for sure.dairyqueen814 wrote:Im on there right now
1997 VL850
dairyqueen814
going to pull the trigger
with the rarity of them its worth absorbing the 25% restock fee
Nick
Nick
- 654 Views
- 12 Replies
- 2548 Views
Last post by eightfifty2x0
- 419 Views
Last post by bmdubya1198
- 15 Replies
- 24729 Views
Last post by amblerman
- 29 Replies
- 7164 Views
Last post by Chuck W
