2002 V70 tie rods quiz
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Left to right: Volvo OE (TRW) inner tie rod + Meyle outer, Lemforder inner + OE outer (and ignore OE outer from the other side). Outer rods are bolted into inners to max depth, inners are aligned.
OE+Meyle is 310 mm, Lemforder+TRW is 320 mm. Your guess what's wrong?
2002V70XC
Year and Model: V70XC 2002
Post by 2002V70XC »
Hi vtl,
Is the Meyle outer tie rod longer than the OEM? I've had Meyle HD outer tie rods (from IPD) that were longer than OEM. IPD staff confirmed it after checking with Volvo.
I thought the non-HD Meyle version would be fine for front wheel drive!
vtl
Post by vtl »
Non-HD Meyle has same length as OE 274175/274176. However, quality may be not up to OE. This Meyle was in vehicle for 1 year, so far so good, but I took it out and replaced by OE, because I had miserable experience with other stuff from Meyle: struts went out in 6 months, sway bar end links in a year.
I've got these OEs on Ebay for $103 w/ shipping.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
vtl wrote:I had miserable experience with other stuff from Meyle: struts went out in 6 months
The Meyle struts didn't last? I was just looking about purchasing them.
vtl
Post by vtl »
oragex wrote:The Meyle struts didn't last? I was just looking about purchasing them.
Nope. I drive that car (V70) only occasionally, so in 6 months I noticed they were... well, not like I put them in half a year ago. When I replaced them in another 6 months, I still had old rusty original struts laying around. 1 year old Meyle struts were worse than 12 years old Sachs. So that speaks best to Sachs quality, I finally decided to put them in the car. New Sachs, of course.
Forgot to mention: everything I had made by Meyle rusted badly. If they'd last, lets say, 5 years, I fear I'd had to use Dremel to cut nuts.
oragex
Post by oragex »
Happy I learned just in time, this saves me time and money. Do you feel the new Sachs are a little bit smoother than the old ones? What color were yours?
vtl
Post by vtl »
Suspension was dead when I bought V70 4+ years ago, so I don't really know how it drove new. In last couple of years I replaced basically everything replaceable in suspension and steering. I've got Sachs with blue label, they feel as stiff as in XC70, which I bought soon after previous owner replaced suspension at dealer. Original Sachs were white label. Remember this is V70, not XC.
Springs are Suplex. I've mistakenly ordered S60 rear springs, which are softer than those in V70, but since wife doesn't carry 4 corpses in trunk too often, she likes unloaded car with softer rear springs better: the ride is not that bumpy like it was. Looking backwards, I'd order OE springs, because lot of aftermarket parts from not very well known brands failed quick enough. Not confident in how long those Suplex'es will last. Darn greed...
oragex
Post by oragex »
Then the blue Sachs must are the standard ones, replacement for the white original ones. I'll go with them too (there's also red Sachs which they say are a little bit stiffer).
2002V70XC
Post by 2002V70XC »
I also had a problem installing the rear Meyle HD sway bar link! One of them had the boot pulled out from the string that hold/tighten its mouth! I couldn't get it back into position so I removed the string and used a zip tie to deal with it. Hopefully its fine!
I was very careful installing them but their design for couterhold the nut is not as good as the OEM one (torx bit). I noticed that all the Meyle parts I got were made in Turkey but i'm not sure if that has anything to do with the quality.
Also their Tie rod ends (HD version) are longer than OEM so they won't fit the XC70 properly.
vtl
Post by vtl »
2002V70XC wrote:I noticed that all the Meyle parts I got were made in Turkey but i'm not sure if that has anything to do with the quality.
"Quality means doing it right when no one is looking" (c) Henry Ford
Answering to quiz: I've got OE outer tie rod (made by TRW in USA) with ~10 mm of uncut thread. Had to cut inner tie rod shaft to be able to do toe-in alignment.
Though this is a good bit of info on Meyle: looks like Meyle has to be avoided, HD or non-HD, doesn't matter Thanks!
