I have a spare model 901 Volvo 3CD/radio/cassette unit I picked up cheap. I had the code so installed it to see if it worked. Radio seems to be fine (no cassettes to hand to try), but when I loaded a 3CD cartridge with 3 CD's in it the unit just kept cycling through the load sequence.
Is it possibly a case of the CD loader drive belt just needs to be cleaned (seen a how-to on-line) or is it a symptom of the CD unit is goosed?
Thanks,
2000 V70R - Radio/CD - CD player not working
- Has thanked: 2203 times
The laser pickup needs to be cleaned. It's not seeing the cd. Google Volvo 901 cd changer repair and you'll be able to find several articles on how to do it. Clean the rollers while you're in there.
2007 S60R Magic Blue/
2005 S60 2.5 AWD Silver/Black
2001 C70 Coupe HPT black/black 149000 miles
2000 C70 Coupe HPT 132000 miles...SOLD
1994 850 sedan n/a 230000 miles...SOLD
2003 GMC 2500HD Crew Cab
1993 Corvette 40th Anniv Convertible
1960 Corvette
1960 Corvette
Many thanks for your guidance! I've already cleaned the rollers, but had planned to clean the laser with a disc/laser cleaner I have, but that won't work if it won't load!
I look up the laser cleaning process and feed back if I have success.
I think you may be able to see it with the cover off on a 901. You may need to tape a q-tip to a long screwdriver to reach it through the face. Use the same rubbing alcohol you cleaned the rollers with. I had both problems. First the cd's wouldn't load, then they just cycled through.
1960 Corvette
1960 Corvette
Thanks guys. Google'd it and found a helpful write up with pictures. I've cleaned the laser and will re-try tomorrow to see if it fixed it.
I have another question. Didn't notice before, but the front cover flap for the 3 disc cassette won't stay closed. Had a look to see what closes it and can't see anything like a spring or anything. No loose bits inside of it. Is there a motor or lever that should hold the flap closed?
It's a tiny spring that appears almost impossible to fix. I just leave a cartridge in it.
1960 Corvette
1960 Corvette
Thanks for the info. I took the original unit apart an saw there should be a tiny 'hair spring' behind the LH end of the door flap when looking from the front. Must have knocked it out when cleaning and not realised. Can't find it anyway.
Re-tried the unit after cleaning the laser and all works now as it should - the spring!
Thanks for all the help guys.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Can someone post a link. I have the same problem just continues to cycle through CDs
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
This is the link I worked from:
http://www.volvoforums.org.uk/showthread.php?t=181209
The only thing I would add is to use a good light to shine through the hole that they mention to put the cotton bud through. The laser is on the lower side, under the yellow sticker area.
To access it, I carefully wound out the cassette drawer by turning the black toothed gear CCW (that is in the hole with the pink circle around it). Do this slowly, until you get the drawer 1" extended and then carefully pull it out slowly.
Once cleaning is completed, slowly slide the drawer back in.
- 1306 Views
Last post by subzerocarfanatic
- 822 Views
Last post by BenV70D5
- 1618 Views
Last post by achmare
- 4142 Views
Last post by 850TurboTurtle
- 2007 Views
Last post by EngineeringBloke
