Hi there;
I have been using the advice of this forum to adjust my parking brake. I have no braking effect with the pedal down. I have the center consul moved to made the cable adjustment a lot easier. It was then that I realized no amount of adjustment is enough. The park brake pads look ok.
I just bought this vehicle a few months ago. I have the back wheels off and I see there are new rotors and pads.
Is is remotely possible that the rotor has the wrong specifications for the drum diameter? This may be far fetched. I am out of ideas. Right now, it seems teh most plausible.
David
2007 XC90 V8 Parking Brake Adjustment
huzzsaba
- Year and Model: 2004 volvo xc90 2.5t
https://www.youtube.com/watch?v=-9bk9vt4-c0
this is a video of a retrofit for the rear emergency brake adjustment. I will be doing this on my xc90 next time I have to do the brakes.
2004 Volvo xc90 2.5t
1998 Volvo s70 T5M
1998 Volvo s70 T5M
Thanks for the replies. I am sorry I didn't respond sooner. I guess I expected an email notification.
Thanks huzzsaba for your interesting idea. I am in the USA. What vehicle was that adjuster from?
@jimmy57; Yes, I took the rear rotors off to see if the drum brakes were actually moving. The pads didn't seem to be worn much. I don't know the tolerances to make an intelligent call on whether they simply need replacing. I guessed that the park brake would be used so infrequently, and only when stopped, that these would basically be a lifetime part.
If the previous owner drove with them engaged they could be toast. You didn't take any pics did you?
I haven't done my back brakes yet but I plan to mine don't work either. I adjusted them in the tranny hump, but that didn't do anything. Have you had someone push the pedal to see if the shoes are actually moving?
Hello Ou2mame;
I guess the previous owner could have driven with the emergency brake engaged and ignored the chime that goes on and on when it is engaged. The cheap starting point is to replace the pads. I didn't take pics. and I didn't measure pad thickness.
Yep, I have done the same as you. wound the adjuster all the way to the end. Brake just causes slight friction now.
Lastly, yes, I have had someone push the pedal and checked they are moving.
There was a suggestion by someone of cable stretch. replacing cables is an expensive proposition.
I am wondering if there was different drum diameters between 2003-2014 on XC90's. I can't help but feel this is the most likely cause but can't find any indication to support that theory.
RosserV70
- Year and Model: 1999 V70
- Has thanked: 1 time
I know this is three years old, but . . . I have the same problem. New shoes, new springs, adjusted the cable according to VIDA and there is still no hold. When I had the wheels off I noticed the shoes moved when the brake pedal was depressed. Did you ever figure out what the problem was?
- 27729 Views
Last post by OnTrack
- 958 Views
Last post by 1997volvo850
- 2920 Views
- 1626 Views
Last post by junkycosmos
- 2209 Views
