Change your brake fluid.
Ludermilch
- Year and Model: 98V70XC 98V70R 01C70
- Has thanked: 1 time
Doing maintenance on my XC brake system I ran into this jewel.
Actually I discovered it residing in my brake lines. It would appear that the previous owner didn't change the fluid as recommended. Once I changed the fluid, I no longer had the shimmies while braking! Wow. Go figure.
1998 V70XC
2001 C70
1998 V70R
2000 Subaru Outback VDC
Perception Fontana Tandem Kayak
2001 C70
1998 V70R
Puppet_Master
- Year and Model: 2002 Volvo S60 Base
That's Disgusting! Glad to hear you fixed the problem. Stopping is very important.
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
Nice to gain an unexpected benefit from a fluid change. If old fluid thickens down inside the caliper from heat and moisture, it may not flow readily back causing the piston to drag or create the shimmy you were experiencing. Recommended change interval in humid environments is yearly, but otherwise every couple of years is good, or at least when pads are replaced.
- 3473 Views
Last post by Krons
- 1586 Views
Last post by EuroDriver
- 31 Replies
- 5561 Views
Last post by VolvoOwl98
- 2334 Views
Last post by cork5695
- 1616 Views
Last post by moonweasel
