I had no movement on the passenger seat now for some time. Decided to but a new seat control unit from eBay. I bought a used one. I switched the seat control out but still no movement. The seat control unit itself clicks b but the motor has no noise no clicking etc.
Can it be a fuse issue? The owners manual says the fuse generally do not need service. Anything else? Odds that I am two for two on defective controls?
1998 V70r Passenger seat control - no movement
Scour the inter webs for a wiring diagram and start at finding the 12 VDC feed to the seat. Wires fuses and connectors are usually what goes if you have no function at all on seats, as opposed to one or two things INOP.
JRL
- Year and Model: Several
- Been thanked: 16 times
Of course you do have the key on?
Thanks but considering I can't really read a writing diagram and it has been stuck at least 2 and maybe 3y I'm fine to leave it alone. It is the passengers problem anyway right?
1988 740 -- Long gone
1998 V70r -- Current daily driver
2004 S60 -- Magically turned into a Toyota Sienna
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Are there fuses for the drivers side and pass side?chexny wrote:Swapped the fuses just to check and not the fuse.
Mine is inop and was just wondering.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
obayha
Thanks. As I will look. I put inn a power seat in my 99 in place of a manual one and it does not work. Anyone know the fuse numbers for the pass side?
Hope you get your problem solved, and you have helped me with trying to solve mine.
1998 V70 T5 331,000
- osman
- Year and Model: 2002 c70 hardtop
Can you hear the motor? After time the wire on the inside of the cable that goes from the motor to the seats, gets frayed and the motor spins but does not engage the seat control. I use heat to shorten the outer sheath which has the same effect of shortening the interior cable and voila. The volvo window and seat motors are nearly indestructible in these cars. They almost never fail. I have seen quite a few control panels for the seats fail.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
- 2124 Views
- 1771 Views
Last post by Sommerfeldt
- 1873 Views
Last post by rspi
- 46 Replies
- 9425 Views
Last post by Rattnalle
- 16 Replies
- 3704 Views
Last post by xHeart
