Hey guys,
I have had some issues with my volvo starting. We have had a record breaking cold snap (3 degrees celsius) in Brisbane and I had trouble starting it.
I assumed it was the cold, so tried to warm it up by pumping the starter motor a bit. However I think I drained the battery.
I then charged the battery, and now its full. I changed all the spark plugs and I checked the distributor cap (it seems ok).
The car now starts for about 2-3 seconds, but then stall and wont turn over again. The dashboard is displaying the mysterious green lambda sign and I can't seem to find it in the manual.
Does anyone know what the issue might be? Attached is a pic of the dash lights, thanks.
1999 Volvo s70 wont start and displays green lambda
faddishworm
- Year and Model: s70 1999
Salomons Driveway
- Year and Model: '87 740 Turbo Wagon
The 850/ C70 forum on this site says the lamba light is the non-US version of the check engine light.
https://www.matthewsvolvosite.com/forums ... =1&t=25459
Try checking for diagnostic codes?
Tim in Dallas TX
Chances are you need a fuel pump relay,...also, can you hear your fuel pump clicking on when you turn on the ignition (but not start the engine?) Other common culprits are crank sensor, and coolant temp sensor. You can invest in an OBD reader to read your lamba/check engine light or have a mechanic read it
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
- 1252 Views
Last post by draser
- 1209 Views
Last post by whtwgn
- 11 Replies
- 2057 Views
Last post by nico416
- 1160 Views
Last post by kcodyjr
- 776 Views
Last post by RickHaleParker
