Hello All,
I have posted a video of the compressor clutch in action and the AC pressure gauge reading here:
My questions are the following:
1. In the video, the engine is idling and the AC is turned to full blast. Does the clutch appear to be working properly?
2. Given that the system is holding pressure, yet the AC is not cold, might the problem be a need to drain and recharge the entire AC system with new R-134A?
Any input would be welcome! Thanks.
93 940 Air Conditioning Not Cold
as 93 said, you are low on Freon. At the auto part store, or walmart )cheapest) get a can of Freon and a hose to charge up your system
When the system is at the correct pressure (not low), you will not even notice the cycling on/off while driving. It really is a night and day difference, and easy to top off yourself.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
e777
- Year and Model: 1990 740
- Has thanked: 11 times
Thanks to you both. My one doubt is the fact that the system is already at maximum pressure. If I add freon I will exceed the pressure limit. So, this has me wondering if I need to have the whole system purged and recharged with all new R 134A...? Thanks again.
Wagons:
93 940
91 240
90 740
86 740
93 940
91 240
90 740
86 740
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Define...e777 wrote:system is already at maximum pressure
If high side pressure is high, then system needs to be taken down, and orifice tube replaced. But, if true, I would flush the whole system out....see video...and replace compressor and dryer.
Low pressure side readings mean nothing in regards to system being "max'ed" out.
