greetings all,
extremely wet & rainy weather has car performing with no power - will not go above 35mph - no smoke from turbo, oil & coolant is clean, no engine lights on, no mis-fire. Engine freely revs when in park, so my initial thoughts of clogged converter cannot be correct - any ideas?
thanks in advance,
1994 940 turbo no power
greetings All,
so taking a closer look today as rain let up I noticed broken vacuum line from MAF to valve connector heading to behind the head - idk what that is, but its pretty fat pipe - 1/2 inch. I also replaced vacuum line from turbo to Y pipe and the two other lines off that - 8mm pipe.
On test drive - theres no change drive exactly the same, with my foot on the floor I cant break 30mph. So now I have engine light - codes are as follows:
A side - 2 -3 -1 followed by 1-3-3
B side 1-2-2
I have no idea how to diagnose these as I only have 240 book which does not contain B side of 94 940, any ideas please??
many thanks in advance,
R
B side 1-2-2
R
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
133- Throttle position (TP) switch faulty at idling.robin_740 wrote: So now I have engine light - codes are as follows:
B side 1-2-2
231 - Long term fuel trim lower limit at part load.
I know a Regina has a IAT, but does a LH 2.4 Turbo? There is a ABS code 122
122 - Intake air temp (IAT) sensor signal absent or faulty.
122 - Right front wheel sensor, circuit fault below 25 mph
I know a Regina has a IAT, but does a LH 2.4 Turbo? There is a ABS code 122 -
means nothing to me - I m a Volvo newbie
changed MAF - too many codes to read - light up like Xmas tree - so I cleared them all, no engine light on now - but still wont go over 30 mph...
now I m really puzzled - spent $$ and its still the same - this is story of my life with cars - heading to Volvo Swedish on orient road
R
R
- 963 Views
Last post by selsworth1
- 881 Views
Last post by robin_740
- 1434 Views
Last post by 93Regina
- 687 Views
Last post by Steelmdi
- 953 Views
Last post by rob2volvos
