In the section regarding the use of a VW airpump as a replacement for my 97 850 Turbo, was the VW pump correct for the Turbo motor? What model VW is it from?
Next horrible issue. I just bought this car and I found the a/c blows cold on the right side but horrificly hot on the left vents no matter where I've set the temp.. I have the auto control type system. If it is a stuck flap as several suggested elsewhere, how do I get to it and what is the repair consist of?
Question on 850 airpump and a weird a/c issue
oldvolvoguy
- Year and Model:
pfeener
- Year and Model:
- Been thanked: 2 times
The air pump assembly is the same for NAs and turbos. I used a VW pump in my 98 S70. I paid $45 on ebay. It isn't so important what year VWs will fit as it is the physical configuration of the pump. If you look at the pump in your 850 you'll see what I mean, but the end of the pump where the wires plug in needs to be of the same type as the Volvo pump; meaning it needs to have the 3 prongs that snap on the end of the motor body and the small output end of the pump needs to be of the same size and orientation as the Volvo pump. You can look at the pictures of the pumps on ebay and you can see what the configuration is.
oldvolvoguy
- Year and Model:
Thanks for the update..I've also been told that the airpump from a Volvo 960 will work doing the same alterations.
This might seem simple and stupid, but have you checked the air mix setting. Make sure it is set so that's it not bringing fresh air... aka the hot air from outside.oldvolvoguy wrote: Next horrible issue. I just bought this car and I found the a/c blows cold on the right side but horrificly hot on the left vents no matter where I've set the temp.. I have the auto control type system. If it is a stuck flap as several suggested elsewhere, how do I get to it and what is the repair consist of?
- Has thanked: 2657 times
- Been thanked: 1248 times
This might help:
https://www.matthewsvolvosite.com/air_pu ... nt_850.php
oldvolvoguy
- Year and Model:
Thanks for the thoughts. I'm well aware of the 850 airpump link here on this site. It just didn't give me enuf info other than a VW part number.
RE the a/c air mix issue..I've certainly eliminated that. My concern is..how do I access the heater control flaps as the issue has been traced to that problem.
- 115 Views
- 2240 Views
Last post by 850oldschool
