Radiator fan runs continuously
BryonTheCanadian
Year and Model: 2006 XC70
Been thanked: 2 times
Post by BryonTheCanadian »
Hi team my rad fan is now running on high from the second i switch on the car cold... If read it could be a defective part on the fan unit or high pressure switch on AC condenser... My Ac does not seem to be working so could be that.. Is there an easy way to disable the high pressure sensor to remove it from the equation? to see if its the Fan electronics... or other ideas B
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
BryonTheCanadian wrote: 23 Apr 2019, 11:23 Is there an easy way to disable the high pressure sensor to remove it from the equation?
1. Disconnect the wire to the A/C clutch so that it cannot be engaged.
2. Pull the wires on the A/C pressure switch and put a jumper across the two wires. 1/2 of a paper clip makes a good jumper.
3. Tape it so it does not get shorted.
If the fan runs correctly you found the source of the problem and can run this way until you get the A/C fixed.
Active
Past
cbova
Year and Model: 2005 XC70
Post by cbova »
Did you find a solution to this? Mine started doing the exact same thin last week. I'll start a new thread with what I've checked so far so not to hijack.
BryonTheCanadian
No have not checked much out. seems it could be 1 of two things either Fan switch or high pressure sensor on AC
BryonTheCanadian
RickHaleParker wrote: 23 Apr 2019, 11:40
Thanks Rick where would the AC pressure switch be located... Thanx
