2000 V70 Sometimes won't start
skjmank
Post by skjmank »
I have an issue with my V70 sometimes not starting. I had the battery checked and it was fine.
Also, the car idles low when I come to a stop. I don't know if these 2 issues are connected. (Maybe a fuel line issue?)
I have a video of the car not starting. You can hear the engine better on the second attempt.
Current Mileage at 270,000
2000, V70 Wagon, 307k+, 2.4 liter, awesome.
2000 S80 (N/A)
1994 850 (N/A)
1985 740 (N/A)
quietlymknnoise
Year and Model: s80 2006
Post by quietlymknnoise »
check immobilizer ring
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
quietlymknnoise wrote:check immobilizer ring
If that was bad, the car would just die after a few seconds, wouldn't it? :?:
I'd say check fuel pressure and hoses first, make sure there's pressure and no air leaks.
Is the car throwing any codes?
- S
[Sold] '97 S70 T5
Has thanked: 1609 times
Been thanked: 4065 times
Vacuum leaks or the dreaded ETB needs service in that year.
skjmank
Post by skjmank »
No codes on the vehicle.
Can you further explain vacuum leaks and ETB? What are they and how do I troubleshoot these issues?
2000 S80 (N/A)
1994 850 (N/A)
1985 740 (N/A)
Of course
Vacuum hoses are the number one trouble of idle and poor running. You need to look at the label under the hood, find every vacuum hose, and trace it to each end, looking for splits, holes, loose fittings do this with the engine off and cold so you don't get burned
If you have a turbo, it's tough to see these without a flashlight and even a mirror
2 ETB was the first electronic throttle body on Volvo. Your gas pedal no longer opens a mechanical valve, it sends signal to motors that open the air valve to the motor. The first one used on the 1999-2001 models was made by Magnetti-Marelli in Italy and lasts about 100 k miles then croaks. It's about 1000 bucks to fix including hardware and software , with cheaper options discussed in the ETB forum
There are no idle adjusts on an ETB car. If the idle is wonky, you've got leaks or a bad ETB
