1995 850 cruise control inoperative
Svenska
Year and Model: 1995 850 GLT
Post by Svenska »
My cruise control stopped working a few weeks ago. The code I retrieved says that there is no signal present (I think the code was 113 or 133...) Does anyone know where the sender/pickup is for that speed signal for the cc?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I am not familiar with that code but the speed sensor to the speedometer on a 95 is mounted on the transmission, sort of near where the oxygen sensor connectors are located. I would give it a look. Check out this recent thread for some pics: https://www.matthewsvolvosite.com/forums ... p?p=376652
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Neither of those codes is a valid code for the cruise. Did you read those codes from port B-2?
Svenska
Post by Svenska »
Wow, I got that DTC number wrong... I did obtain the code from the B2 port. It's 122 "speed not been above 35 kph or no vehicle speed signal". Where is that speed signal? The speedometer works.
Post by Ozark Lee »
You always get the 1-2-2 if the car has been turned off. It is a silly code since you can't really read it while you are driving down the road.
There are a bunch of things that can fail with the cruise but the procedures and the Mode 2 diagnostics in the factory manual are an excellent resource to sort things out. If you don't have it the factory manual is here:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
One of the most common failures isn't dealt with in the manual and that is the hard plastic line that goes between the area under the battery and the firewall, it has a tendency to crack and leak.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I fixed the cruise on my '99 S70 by changing out the stalk with a $10 junkyard part. a bad switch is a pretty common problem and pretty easy fix.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
